GLITCH / Font SIZE and MENU
15 years 6 months ago - 15 years 6 months ago #542 by hayden
GLITCH / Font SIZE and MENU was created by hayden
Some have noticed a glitch with IPYOA, and I am aware of this, and I need to upgrade the template to solve this. But, in the mean time, the solution is simple. REDUCE YOUR font size one click, or two with the A- A+ buttons in the top right of the page until the menu ENDS with EVENTS.
If you see the EVENTS menu item on the second row, then your font is too large for this design template.
Here are photos showing the issue and what to look for.
This image shows the menu in the proper position and the site is fine...
CLICK IMAGE FOR LARGER VIEW
This image shows the font increased and the menu wraps which pushes some of the page layout into odd positions.
The solution is....I need to upgrade the site template to a newer and cleaner design. Replacing this template and re-designing the modules into a new template will take about 8 hours. I plan to upgrade this soon and fix this issue.
Sorry for the glitch...
Last edit: 15 years 6 months ago by hayden.
15 years 6 months ago - 15 years 6 months ago #543 by hayden
Replied by hayden on topic Re: GLITCH / Font SIZE and MENU
OK....since no one used the EVENTS CALENDAR, I removed it. Maybe this will help with this glitch of the menu wrapping into the second line.
Solution: I need to upgrade the site template. Eventually I will.
Right now, I am building and adding a massive community sharing/facebook/grouping/sharing application that will REALLY BE COOOOL. After this has been added we should have the ULTIMATE IP sharing web site.
OK,
Enjoy the connectivity...
(PS, the Events calendar took me 12 hours to install and build!)
Time to create page: 0.284 seconds
We have 1017 guests and no members online
