- Thank you received: 1
SOLD: 1995 IP 37 For Sale PRICE DROP $110K
- Marko Markovich
Topic Author
8 years 11 months ago - 1 month 2 weeks ago #5883
by Marko Markovich
SOLD: 1995 IP 37 For Sale PRICE DROP $110K was created by Marko Markovich
EVERYTHING LISTED FROM HERE UNDER IS BRAND NEW PURCHASED AND INSTALLED IN 2016/2017
BG 4G radar mounted on mast with Kato Marine mast mount.
BG Zeus 3 9" Chartplotter in cockpit AND in Nav table inside.
All brand new Doyle sails from 2016 with sunbrealla in the color toast.
Bluewater StackPack Main.
-Lazyjacks, 2 reefs, 4 full battens
Bluewater Roller Furler Genoa
-135%
Bluewater Roller Furler Staysail
-78%
Brand New Raymarine Equipment.
-Raymarine EV-200 Autopilot system with hydraulic pump unit
-Raymarine I70 System pack with wind vane, depth and speed sensor.
-Extra Raymarine I70 Screen in cockpit.
Magnum Energy 2800W 12V Inverter/Charger.
1 300 Watt Solarworld Mono Solar panel installed on dinghy davits.
MORNINGSTAR TRISTAR TS-MPPT-45, 45A MPPT CHARGE CONTROLLER
Trimetric 2030 Battery Monitor
2 Trojan T-105 batterys.
Kato Marine stainless steel dinghy davits with 6:1 pulley system to lift up the dinghy.
Solar panel mounts on top of the dinghy davits with stabilizer mounted on the davits.
Good Windlass F850C Free-drop rope/chain windlass w/ 9/16" x 300' anchor line kit w/ 10' BBB galvanized chain lead.
Isotherm 3701 ASU Air Cooled Refrigeration Component System
All new dodger and bimini over the cockpit.
Stainless steel framing with sunbrella Toast fabric.
Has zippers to finish off to a full enclosure.
Rule 2000GPH bilge pump
All new LED lights around the interior of the boat.
Signal Mate LED Masthead light with automatic turn off sensor.
Bottom was stripped to the gel coat in 2017 and had 8 coats of Interlux 2000 Epoxy applied as well as two fresh coats of bottom paint.
Marko Markovich
631-813-8492
-135%
-78%
Marko Markovich
631-813-8492
Last edit: 1 month 2 weeks ago by hayden.
- Marko Markovich
Topic Author
8 years 11 months ago - 8 years 11 months ago #5884
by Marko Markovich
Replied by Marko Markovich on topic 1995 IP 37 For Sale
Last edit: 8 years 11 months ago by Marko Markovich.
- Marko Markovich
Topic Author
8 years 1 month ago #6232
by Marko Markovich
Asking $110,000
Time to create page: 0.041 seconds
