IP40 rudder bottom shoe
- [email protected]
Topic Author
7 years 6 days ago #6677
by [email protected]
IP40 rudder bottom shoe was created by [email protected]
We just purchase an IP 40 - after the haul-out, I noticed the arm the that attaches to the bottom of the rudder will move vetically about 1/2" (on the lower bearing end) - normal or isssue ??
Bob
Bob
7 years 3 days ago #6678
Replied by hayden on topic IP40 rudder bottom shoe
Bob:
This bar, officially called the "WEED SHOE" by the designer, is non structural to the yacht. It is only there to prevent kelp, or lobster pots or crab pots from catching on the bottom of the rudder. Many people think it is required for he rudder and it is not. The rudder structure is based off the two large bearings in the hull. The section where it is on the bottom of the rudder is simply there to make the connection. All support for this weed shoe comes from the screws and bolts that are back on the sides of the keel. If it moves a little up and down or sideways and it is not showing loose screws at the hull, FORGET IT. leave it alone, launch and go sailing.
The following user(s) said Thank You: Andersond113, stevetrego
- [email protected]
Topic Author
7 years 3 days ago #6679
Replied by [email protected] on topic IP40 rudder bottom shoe
Hayden - thanks for the answer - new boat to us - so I'm sure I'll have more questions
Time to create page: 0.040 seconds
