Watermaker Needed? (Poll)
Poll: Do you think a watermaker is needed and worth the expense for cruising the Bahamas and/or Caribbean? (was ended 0000-00-00 00:00:00)
Yes, it is absolutely needed, DO IT
14 35%
Yes, its a nice option, but not needed
25 62.5%
No, forget it, you can buy water
1 2.5%
Total number of voters: 40 ( blindfaith, chasecreek, Kairos, Captdah, IslandWanderer ) See more
Only registered users can participate to this poll
15 years 11 months ago - 15 years 10 months ago #523 by hayden
Watermakers are expensive, they need to be run weekly, or very often, and they need LOTS of power to make water. If you were going to the Bahamas and maybe the Caribbean Islands where you may cruise 3-6 months a year, would you invest in a watermaker?
Which one?
How would you power it?
How long does it take to pay off, and make it worth it?
Echo Tech:
www.echotecwatermakers.com/seawater_desa...mmercial_vessels.htm
Spectra:
www.spectrawatermakers.com/
Village Marine:
www.villagemarine.com/
Others????
Last edit: 15 years 10 months ago by hayden.
15 years 11 months ago #524 by pxlancaster
Replied by pxlancaster on topic Re: Watermaker Needed?
A water-maker is not essential and I would doubt that you'd ever recover your investment but it sure as hell is nice when you see the poor devils on the next boat having to jug it from sure every time you put the hook down.
It's like all things boating, very little is actually essential but there are a whole lot of goodies that are nice to have and WM's come under that heading.
Mine is an old one and works fine but I need to run my generator and probably run it about once a month in the Caribbean, probably more often in the Bahamas. Last year there was a major drought in the Windward's and water was hard to find and then it was subject to rationing so the old WM came in very handy. Also after hurricane Tomas went through St Lucia, we were without water for two weeks so again it was nice to have the option.
If I was to buy a new one my choice would be Spectra as you can make water form sunshine and it's quiet
Peter Lancaster,
Traa Dy Liooar
15 years 11 months ago #527 by ipsailor
Replied by ipsailor on topic Re: Watermaker Needed?
We have a 110 volt Aquamarine watermaker. Got that one because we have a generator and it makes 24 gallons an hour. It is really nice to have when in the keys and we plan on using it in the Bahamas. Along the east coast you really cannot use it because the pre-filters get clogged to easily. We pickled ours when we were half way north in Florida and will start using it again when we get over to the Bahamas.
Jeff
IP380-133
Xperience
15 years 11 months ago - 15 years 11 months ago #528 by edkelly
Replied by edkelly on topic Re: Watermaker Needed?
We love our Spectra. I was not going to get one due to the Cost being so great. But a cruising friend reasoned with me and pointed out that at some time - especially if you like to anchor in secluded anchorages and not at a dock - you will be low on water and weather won't be good. Then it becomes a safety issue. He had seen several boats make journeys when they otherwise might have stayed, all because of no watermaker.
Best buys on Watermakers is from Barry, a Brit who stays in Curacao in the south Caribbean. He constructs them for a fraction of what commercial ones would cost and those with his all rave by them. We have a Spectra 150 (small size was only one that would fit our earlier vessel) - now wish we had the 300 model! Ed
Ed & Sue Kelly on ANGEL LOUISE, Catalac 12 Meter Cat, USCG documented Cruz Bay, USVI, cruising 24/7!
Last edit: 15 years 11 months ago by edkelly. Reason: typo
15 years 11 months ago #531 by cnelson
Replied by cnelson on topic Re: Watermaker Needed?
With our aluminum tanks what better way to ensure nothing bad gets in them.
15 years 11 months ago #535 by paulb
Replied by paulb on topic Re: Watermaker Needed?
We put in our 240 volt watermaker at the same time as we installed a generator. We've found them both very useful as we cruised the west coast of Ireland and Scotland. We spend a lot of time at anchor and it's great not to have to worry about how much water we use. It's not essential but it is a real nice to have.
We installed a D60 Dessalator CRUISE Watermaker and a Paguro 300 compact generator. Both have performed well over the last 3 years.
Paul Bragg
Jennie B IP 380-163
Paul Bragg
IP 380-163 Jennie B
Time to create page: 0.057 seconds
