Fill it UP, really?
16 years 3 days ago #497 by hayden
Fill it UP, really? was created by hayden
OK, I will jump in here....On our first charter of a sailboat we had to motor a long way, I mean really, really far. We motored from Kent Island, MD, all the way down the entire Eastern Bay to St. Micheal's, MD. This trip was aboard a Pearson 33 with a diesel motor. So of course when we arrived at this far away destination of about 10 miles, we proceeded to the Saturday-afternoon-busy fuel dock where we asked the guy to fill it up. He put in the hose and pumped in about 1 gallon and it backed up. He said it was full. We said NO WAY, we motored all day long! He asked, where did you come from? We said: "Kent Island!" very proudly! And then he laughed....you idiots....you can motor the entire Chesapeake Bay on one tank. You do not need fuel after 3-4 hours of motoring a sailboat! NO WAY...this is cool we thought!
So we moved off the fuel dock and proceeded to take a slip because it was way too scary to anchor out!
That was our first charter! Oh, the fun we had before we knew what we were doing.
15 years 1 month ago #1078 by jcamsr
Replied by jcamsr on topic Re: Fill it UP, really?
Another "fuel" tale:
After we bought our first sailboat, a Catalina 27, my son and I were bringing her from Warwick, RI to her new homeport @ Newburyport, MA--a long three day trip. I checked the fuel tank gauge before we left and it read full!
We sailed some down Narragansett Bay, but once outside in Block Island Sound and up through Buzzards Bay it was a long slog in sloppy seas and the wind on the nose so we went to the diesel. The second night we took a berth in Sandwich Harbor and the gauge said the 18 gallon tank was still 1/2 full which would be about right based upon the running time. The next day's run from the eastern end of the Cape Cod Canal to Newburyport is another long haul, so I filled the tank. A wise decision--I put 17 1/2 gallons into an 18 gallon tank!
The boat was only two years old, and in my wildest dreams, I wouldn't have thought the gauge would fail so quickly. I haven't fully trusted diesel gauges in boats since. It was a good lesson, cheaply learned, and now I always keep track of engine hours between fillings.
When we bought our IP32 she was 15 years old, and one of the first things I did was check the gauge reading vs. the amount of fuel it took to fill, that gauge was way off too.
Since that first Catalina experience, when filling up I always note the gauge reading and the gallons it take to fill. Over the years I have been able to make up a reasonably accurate chart of gauge readings at 1/4, 3/8 1/2, 5/8, & 3/4 vs. gallons to fill and always after filling check the gallons bought against what I think it should have taken. With the new vertical type WECO gauges the readings have always been close.
Jim Campbell
IP32 #1
South Wind
13 years 6 days ago - 13 years 6 days ago #2401 by Subvet
Replied by Subvet on topic Re: Fill it UP, really?
Whats nice about our IPs is that you have two fuel gauges, one readout in the cockpit instrument panel, the other is under the cabin sole, directly mounted to the fuel tank.
Our first boat, an IP-35 was very accurate.
Our present boat, an IP-29 is also very accurate when both gauges are compared.
John Longo
IP-29 /62
Last edit: 13 years 6 days ago by Subvet. Reason: mis-spelled word
Time to create page: 0.036 seconds
