IP 38 antifoul
- markrodger
9 years 8 months ago #5445
by markrodger
IP 38 antifoul was created by markrodger
Starting to get organised to paint the bottom, this year I will be doing it myself rather than getting a yard to do it. So my question is how much is required for two coats for our IP38. Also has anyone used copper coat and if so how much is required.
Regards
Mark
Regards
Mark
9 years 8 months ago #5446
Replied by hayden on topic IP 38 antifoul
Mark:
We use Trinidad Paint and we paint once every 3 years. Out IP 35 takes 1.5 gallons for one coat. We only put on one coat every 3 years. With 2 gallons we use the left over .5 gallon to apply a second coat around the waterline. I would think you can coat one coat with two gallons on a 38.
- Unseasing380
9 years 7 months ago #5524
by Unseasing380
Replied by Unseasing380 on topic IP 38 antifoul
I did a bottom job on my IP 380 using Trinidad SR hard paint in 2015. After 2 years in Florida waters it still looks good. I sanded off many coats of old paint using an electric 6" orbital sander. I did not sand to the gel coat but did remove 90% of the old paint. Where I did sand through, I applied 3 coats of Pettit high build barrier primer.
I applied 2 coats Trinidad SR and it took 2 gallons.
Pettit has a calculator.
www.pettitpaint.com/paint_calculator.asp
Using this calculator I thought I would have needed 3 gallons, (called for 1.3 gallons per coat) I applied using a small diameter foam roller and mixed the paint using a electric drill and mixing paddle. News says Trinidad SR may be available with the biocide Irgarol. See the article Bottom Paint Update in the April 2017 issue of Practical Sailor.
Moderators: JRGabor
