"Ding" in my rudder and repair needed
- paulhelweg
Topic Author
14 years 9 months ago #1225
by paulhelweg
At the end of this season I was moving very slowly in reverse and banged the base of my rudder in reverse; put a 1-2 inch "crush" hole in the rudder glass; after hauling did not notice any watering evidence of the rudder. I have to patch this and it does not look to be too bad a job; I don't think I need to remove the keel "shoe" under the rudder, though the marina folks say it should be removed to properly make the rudder repair. Several other nautical "dermatologists" and craftspeople disagree.. Any helpful comments out there as I think I'll do this work myself and NOT remove the keel shoe.....
I sailed the boat for three weeks after this incident with no discrenable negative affects noticed at the helm...
Hope others out there can offer comments and suggestions before I start this project in late April.
Paul Helweg; Wickford, RI
"Ding" in my rudder and repair needed was created by paulhelweg
14 years 9 months ago #1228
Replied by hayden on topic Re: "Ding" in my rudder and repair needed
Paul
The keel shoe or weed shoe is non-structural. It is there only to help keep lines off the rudder. The rdder structure is all based on the shaft bearings at the top in the hull and seat area. So, glass over ther hole, fill it with epoxy sand it and paint it. No real worries. The ruddes are made of two fibergoass clam shells glassed together then filled with foam. So your damage is a crushing oo the shell. So reglass the shell and spape it in. I would not remove the weed shoe if its not bent.
- paulhelweg
Topic Author
14 years 9 months ago #1230
by paulhelweg
Replied by paulhelweg on topic Re: "Ding" in my rudder and repair needed
Hayden, I appreciate your comments. All along I've been circumspect of the marina/yard manager who quoted me a price of $3,300 to remove the weed whatever, remove and repair this small hole in the rudder. Several other local marine "glass" people looked at it and none said it was more than a $500 job at the most. Not having had experience in this area I wasn't sure but was almost certain the marina manager was just doing a good job of trying to "soaK' the customer.
I intend to do the job myself and perhaps shell out a maximum of $300 for some help from one of the local glass experts. Just needed some reassurance before taking that tack.
More to follow but I feel much better.
I'll also be in Sanibel Island, FL in another month and intend to drive up to Largo and visit the Island Packet shop there and learn a bit more about our boat. Should be very educational and interesting.
best,
Paul Helweg/Wickford, RI
best,
Moderators: JRGabor
Time to create page: 0.038 seconds
