- Thank you received: 1
Screw hole sealant
5 years 7 months ago #6953
by Flyrod
Screw hole sealant was created by Flyrod
I am redoing my teak, taking off the metal belly bands and chafing plates.
The length and size of screws taken out are not uniform and many came right out with no resistance, meaning not actually biting into the wood. I actually wrote down the size screw for each hole so I could be the "right" ones back in.
When I put them back in I want to use a sealant and adhesive.
The holes are small so a caulking gun cannot be used. Should I just dip the screws into either Silpruf, Sikaflex or 3m 5200?
Any thoughts or suggestions?
5 years 7 months ago #6954
Replied by hayden on topic Screw hole sealant
Brice:
To make the screw bight into the loose hole, take a splinter of teak and hammer it into the hole. This will help. As for caulk, I see no problem with 5200 or 4200 3M.
The following user(s) said Thank You: Flyrod
5 years 7 months ago #6967
by ddbrit
Replied by ddbrit on topic Screw hole sealant
Hi...on my 350 I’ve replaced many screws as Hayden mentioned with a splinter of teak dipped in epoxy. The epoxy hardens the surrounding wood as well as seals.
Time to create page: 0.036 seconds
