Jammed Mainsail, Seeking Solutions
8 years 9 months ago #5959 by Jeffrey Cardenas
Furl jammed tightly below the spreaders. Furling ratchet on Free. Tried strong outward pressure on foot with outhaul. Tried strong downward pressure on leach with mainsheet. Climbed the rig and tried pounding the jam free with a mallet and wooden peg. Even slacked the halyard. The furl is just wadded up inside the mast. I’m solo in an isolated anchorage. Any ideas?
8 years 9 months ago #5962 by IPABill
The most reported issues with furling masts were resolved by making sure boom vangs were loose during furling/unfurling sequences. Don't know if RAISING the boom with the topping lift might help the current jam. MIght be worth a try. Hope it has resolved itself by now!
8 years 9 months ago #5963 by Jeffrey Cardenas
Thank you for the suggestion but after six hours and three trips up the mast the solution was finally to remove the Bimini and pull the boom down below level. When I cranked again on the outhaul with max pressure the jam finally released. I just need to be a lot more cautious when I furl. I was sailing into a new anchorage after dark. I wasn’t focused on making a perfect furl and I paid the price.
The following user(s) said Thank You: Islandoctor
8 years 9 months ago #5964 by IPABill
Good to hear. Rooting you on!
8 years 9 months ago #5966 by Amekaya
The times that our mainsail jams I usually work it out by continuing to work the sail alternating between the outhaul and the furler. As Bill suggested take off the vang, raise the boom and having wind helps. When I get it out to where it stops, I then furl it in a few turns with the outhaul stopped and then repeat on the outhaul to where it stops and then repeat the furling. Just before we left Rio Dulce last month I tried to get our main out after being in all summer. For whatever reason it was bunched up. It took me close to an hour of working it back and forth that way but it finally came out. Just work it until it stops and then go a little tighter. They key issue with the in-mast furling is it has to be kept tight when furling and unfurling just like you need to keep pressure on your other furlers when hauling in and out. Another thing I've found is that occasionally the furling line will jump over one of the screw threads and jam especially if unfurling too quickly. Hope that helps for next time.
8 years 9 months ago #5967 by Jeffrey Cardenas
Thank you Amekaya. I will follow your suggestions. Another thing occurred to me...Sometimes I leave the ratchet on FREE after the sail is furled. I wonder if this lets the furled sail inside the mast slowly unwind making the bundle larger in diameter and thus more difficult to come out. I've got a good tight furl in now, and I'm leaving the gear set on RATCHET. It's a better discipline anyway, to prevent inadvertent unfurling in a squall. But in my case I've never had a problem with it coming out too easily :)
Time to create page: 0.042 seconds
