IP 38-80 Reefing Line Questions
3 years 4 months ago #7452
by JHSmith
IP 38-80 Reefing Line Questions was created by JHSmith
Newbies here, Justen & Stacy - we just bought IP38-80 (soon to be JeReca) and are putting her back together without help from the previous owner. Plenty of issues along the way just to get her functional, and now focusing on some of the rigging. Trying to figure out the Reefing system and I'm assuming something is missing, or we're just plain doing it wrong. Plus it helped to get the bird nest out of the boom (no eggs or chicks folks!)...
Please see our pictures and let us know how these should be routed, or if something is missing.
Thank you!
Thank you!
- MacMcDermid
- Thank you received: 2
3 years 4 months ago #7457
by MacMcDermid
Replied by MacMcDermid on topic IP 38-80 Reefing Line Questions
On the "slab reefing", also known as "jiffy reefing" there are two reef lines as in your picture. There should also be what is called a shuttle cock - two pairs of blocks that run inside the boom. As you reef you should pull both reef lines together.
One thing I notice on your pictures, which I think is incorrect. The red line that goes from the end of the boom, up through the first reef point, should dead-end directly back down on the boom in-line with where the aft reef point (grommet) should be on the boom. But, in your pictures, it goes through three additional grommets. Those three grommets are actually intended for three separate short lines to tie the loose folds to the boom after you have set your reef point. They are not intended for the type of load induced on the sail when reefed - they are simply tidying up tie downs (think sail ties when you douse/drop your mainsail).
Your green reef lines should be attached to the second reef points. The reason you pull both sets of reef lines even if only setting the first reef point is to avoid the shuttle cock inside the boom from getting fouled (tangled in loose line).
Hope this helps.
Mac
Hope this helps.
Mac
Time to create page: 0.034 seconds
