- Thank you received: 2
mounting a radar pole on teak rail
11 years 4 months ago #4042
by cat30
mounting a radar pole on teak rail was created by cat30
I have a garhauer radar pole i'm mounting on the teak rail on my transom of IP31.
I'm thinking i need to drills hole all the way though and thru-bolt it with a backing plate? Not sure if i want to run the cable through it also or outside the pole through fiberglass thru a deck fitting?
thanks
Don
LAZY SUSAN
1988 IP31 #192
thanks
Don
LAZY SUSAN
1988 IP31 #192
11 years 4 months ago #4051
Replied by hayden on topic mounting a radar pole on teak rail
Donn:
I have mounted Kato Davits and a 9 foot wind machine pole to my teak gunwale area. I simply used large SS round heads or oval heads and screwed these iunto the teak and into the fiberglass under the teak. I drill a small pilot hole and screw it down. The reason I have not thru bolted these is that the bottom of davits and the bottom of a pole, the forces are for and aft, NOT pulling UP. If the force was pulling up, then I would thru bolt and backing plate these areas. I have 15 years of use with these davits simply screwed to the teak, I carry a 10 foot RIB with a 15 Yamaha, guess what? They are still in place and not loose.
My wind machine pole is mounted the exact same way, simply screwed into the teak and it has braces forward and one sideways. So again, the forces on this pole base are lateral not up. So I simply screwed it down. I am a firm believer in the KISS process. This is simple and it works just fine.
Then again, if you want to thru bolt the base, it would not be that big of a deal.
Time to create page: 0.042 seconds
