Inverters
11 years 11 months ago #3680 by jogiwinter
Inverters was created by jogiwinter
We need to replace our charger / inverter, has anyone got any recommendations of make or model
for an IP 45
11 years 11 months ago #3681 by mcduck52
Replied by mcduck52 on topic Re: Inverters
I was just reading an article on inverter/chargers in Practical Sailor March 2010 issue in which their choice at that time was a Mastervolt Combi 12/2000-100. The RFI emissions safe zone was short and RFI emissions were very low. I have an IP 40 with the old Heart interface and I believe I am having issues with my SSB due to the proximity of the inverter and high RFI.
11 years 11 months ago - 11 years 11 months ago #3682 by hayden
Replied by hayden on topic Re: Inverters
Joe:
I have the Xantrex ProSine 2000 watt inverter/charger. I have had this since 2001. One time I had to send it in for repairs and they fixed it free of charge. If I were buying one again, I would buy this one. At 2,000 watts, we can actually run the hot water heater which is crazy, but on a cold AM with the engine on, we can turn on this inverter and flip on the water heater. Then in 10-15 minutes we have hot shower water. NOTE: We rarely do this, but it does work. We mainly use this to make the 120 outlets hot on anchor which then can run laptop chargers and a TV and Microwave.
www.xantrex.com/power-products/inverter-chargers/prosine-2.aspx
copy of info from url
2000 Watt Pure Sine Wave Inverter/Charger
Provides 2000 watts of pure sine wave AC power from a DC source and 100-amp multistage battery charging.
A powerful all-in-one solution, Prosine 2.0 inverter/chargers (part#805-2000 – hardwire version) deliver up to 2000 watts of unsurpassed clean pure sine wave output power and combines this with a 100 amp, multistage battery charger. Series stackability allows for two units to power 240 VAC applications such as power tools, over ranges, washer/dryer combinations and air conditioners. The Prosine 2.0 is ideal for upgrading your electrical system in a boat, RV, or a utility vehicle. The system includes a full function LCD remote control panel and battery temperature sensor.
Last edit: 11 years 11 months ago by hayden.
11 years 11 months ago #3683 by Augydoggy
Replied by Augydoggy on topic Re: Inverters
A few years ago we installed a Magnum Pure Sine 2800 that includes a 125 amp charger. We wanted the big charger because we have a 750 a/hr house bank and didn't want to spend hours bringing it up to 100%. We also had issues with some equipment not liking the "modified sine" power we got from our old inverter. This past summer we had a water leak from one of our ports short out the inverter. Magnum replaced it without a question, not even a whimper. Highly recommended.
Time to create page: 0.049 seconds
