Honda Generators
12 years 3 months ago #3317 by drljjj
Honda Generators was created by drljjj
Anyone use a Honda generator. I have the Companion model with the 30amp outlet. I tried it and had the reverse polarity light come on. I've done quite a bit of searching online and this isn't an issue. Wondered if anyone has used it on an IP? Thanks
12 years 3 months ago #3325 by rlwestlake
Replied by rlwestlake on topic Re: Honda Generators
We use the same unit without issues. Search here and IPHomeport and I think you will find discussions by others with your experience.
12 years 3 months ago #3326 by tmayo
Replied by tmayo on topic Re: Honda Generators
We borrowed a Honda 2000 to run Christmas lights (mast, forestay, backstays, lifelines) for about 3 hours and it was great. No problems, but can't remember if we ran direct from the generator or through boats' ac...anyway, now I want one too!
12 years 3 months ago #3327 by drljjj
Replied by drljjj on topic Re: Honda Generators
rlwestlake,
Did you run your generator through boat AC system (through the shore power outlet)? Did your reverse polarity light/alarm come on?
12 years 3 months ago #3329 by rlwestlake
We run a shore power cable to the shore power 30 amp connection in the cockpit and flip on shore power as if on the dock. Our primary use is to make hot water on a lay day, but also use it for a cabin heater in the shoulder seasons. No reverse polarity issues. Great power source that comes to the house during layup. Last use at the house was Hurricane Sandy, but I run it from time to time to keep it healthy (important preventive maintenance).
12 years 3 months ago #3331 by Emergpa1
Replied by Emergpa1 on topic Re: Honda Generators
drljjj wrote: Anyone use a Honda generator. I have the Companion model with the 30amp outlet. I tried it and had the reverse polarity light come on. I've done quite a bit of searching online and this isn't an issue. Wondered if anyone has used it on an IP? Thanks
I have a honda 2000 which so far has only serve to run a blender. I have not yet needed to run it to charge batteries. I have read that you cannot run an air-conditioner with a single Honda 2000. I think that is probably accurate. You would need to string two generators together. In retrospect (I upgraded my Engine alternator) probably do not need the generator. Unless of course your need for a blender is significantly high. I can get by on Jack Daniels and Coke
Time to create page: 0.055 seconds
