Rudder Shake
4 years 11 months ago #7142 by Pound_foolish
Rudder Shake was created by Pound_foolish
I have a 2002 IP420 that has a rudder that shakes. Every 15-30 seconds or so, there is a shudder that lasts for one to three seconds then stops. I noticed there is freeplay in the forward rose joint (aka heim joint) and I wonder if this could be the cause. According to my Whitlock manual this either part# AHFT10 or AHFT12. There is a teflon bearing in the joint that looks like needs replacing. Anyone know if this is a user-sercicable part and where i can find parts?  Also curious to know if this is typical. Thanks!
4 years 8 months ago #7172 by Barrys
Replied by Barrys on topic Rudder Shake
Hello PF,
Had a similar issue on our 1996 IP45. We found some loose fittings on the rack and pinion steering and simply tightened them up. Problem solved.
In regards to replacing the part #'s mentioned is there any manufacturer info on the system. They may have bulletins on their website. Good luck as that shudder mentioned is uncomfortable!
Barry
4 years 8 months ago #7173 by Pound_foolish
Replied by Pound_foolish on topic Rudder Shake
Thanks for replyuing. I found a replacement joint on McMaster Carr. I still have some shake but somewhat improved. Ill check the rest of the linkage as you suggest.
4 years 5 months ago #7259 by kabeckett
Replied by kabeckett on topic Rudder Shake
Hello PF,
I have a similar age IP420 and have just stared noticing similar symptoms to the ones that you experienced. I'm interested to know whether you have cured it? Many thanks, Keith
4 years 5 months ago #7260 by Pound_foolish
Keith, it appears slightly better after replacing the ball joint, but definitely not a cure. I noticed prop wash seems to play a part as well.
4 years 5 months ago #7261 by kabeckett
Many thanks. I’ll have a look at the ball joints. Mine seems worse going downwind as the load comes off the rudder. K
Time to create page: 0.042 seconds
