IP 370 Frigoboat
9 years 9 months ago #5415
by Bob Lyon
IP 370 Frigoboat was created by Bob Lyon
We are having problems with our frigoboat keel cooled freezer. The compressor is running continuously and not reaching the 14.5 F set point. For about two weeks has hovered around 16 F now climbing to near 20F.
The evaporator has about 1/8 to 1/4 inch of frost all over it . I do not believe defrosting will help at this time as unit was not reaching set point right after last defrost.From what have read a fully frosted evaporator and still not reaching stepping means inadequate cooling capacity for the load.Has anyone else experienced this problem? It seems worse when freezer is full.
Thanks in advance for any help!
Bob Lyon
Hull number 73
Bob Lyon
Hull number 73
9 years 9 months ago #5439
by solent
Replied by solent on topic IP 370 Frigoboat
Hi Bob,
We have had this on our 440. Two things that seem to help is removing as much card and packaging from items in the freezer. The other things is to ensure the catch is fastening down tight enough. We regularly tighten the nut on this to make sure the lid seals properly. Warm sea water also has an effect on performance.
Best wishes
Jonathan Paull
Seraphina of Chichester
IP 440/01
Best wishes
Jonathan Paull
IP 440/01
Time to create page: 0.030 seconds
