iP380 Diesel Standpipe
6 months 1 week ago #7577 by PJ
iP380 Diesel Standpipe was created by PJ
I have been getting problems with blockages at the bottom of the diesel fuel standpipe in my IP380. I have had the tank cleaned, but there are still small amounts of bug residue. The clearance between the bottom of the pipe and the tank bottom must be too small.  I removed the fitting at the top of the pipe, expecting the standpipe to be attached to it, but this is not the case. It seems to be attached to the welded fitting at the top of the tank.  Does anyone know how or if the standpipe can be removed (so I can shorten it by a small amount).?
3 months 3 weeks ago #7582 by Gryphon
Replied by Gryphon on topic iP380 Diesel Standpipe
You might consider unscrewing the fuel gauge and inserting a suction tube to the bottom of the tank to suck out whatever is at the bottom of the tank. This would allow you to pull from the bottom of the tank below the level of the fuel pickup. I'm in the process of doing this proactively to check for water at the bottom of the tank. You might also consider researching Fuel Right : it dissolves the biofilm off of tank walls and clarifies fuel, but that residue may still need to be removed from the tank. The Boat How To diesel engine course covers this topic extensively; I'm taking this course now and it is well worth the money.
Time to create page: 0.037 seconds
