Wet Exhaust Hose Replacement
- [email protected]
2 years 10 months ago #7489
by [email protected]
Wet Exhaust Hose Replacement was created by [email protected]
A recent survey of my 2000 IP380 suggested replaceing the wet exhaust hose from the mixing elbow to the thru-stern. I can in fact see small hairline cracks on the surface of the 2.5-inch wire reinforced hose.
The problem is accessing the hose connection at the interior side of the discharge or thru-stern.
Has anyone tackled this challenge?
1 year 10 months ago #7540
by GB
Replied by GB on topic Wet Exhaust Hose Replacement
Hi Guenther,
I’ve the same problem on my IP 350 from 1999. Did you find a solution? Do you have some advice?
Many Thanks
Giuseppe
Many Thanks
Giuseppe
- yaoiniymalchik
9 months 2 weeks ago - 9 months 2 weeks ago #7567
by yaoiniymalchik
Replied by yaoiniymalchik on topic Wet Exhaust Hose Replacement
Yes, replacing the hose on an IP380 can be tricky due to limited access to the thru-hull connection. A few solutions others have used include
tropical-casino.com/
Removing the aft cabin panel or accessing through a cockpit locker to gain better reach.
Using a flexible hose or a longer reach hose clamp tool to handle tight spaces.
Detaching the exhaust elbow to make the removal easier.
It can be a tight fit, so patience and possibly a second set of hands are crucial.
Last edit: 9 months 2 weeks ago by yaoiniymalchik.
Time to create page: 0.047 seconds
