LPG Solenoid Wiring - 380:
- [email protected]
3 years 9 months ago #7381
by [email protected]
LPG Solenoid Wiring - 380: was created by [email protected]
I am hoping someone can tell me where the LPG solenoid wiring runs, between the compartment with the tanks, and the electrical panel.
I had one of the two wires breakoff behind the tank compartment, and am wondering if I can put a messenger line on the remaining wire to pull it though to the elec panel, and then pull new wires back to the compartment?
Any advice much appreciated.
Brian Kelly, Northern Lights IV, 380 #45, Winnipeg, Manitoba, Canada, lying Red Hook, St. Thomas, USVI
3 years 8 months ago #7392
Replied by hayden on topic LPG Solenoid Wiring - 380:
Brian:
The propane 12v wiring runs up from underneath the propane tank area. You need to pull out the seat back cushions and then look upward to the deck and you will see the factory wire tied these wires up under the propane tank area. Cut these zip ties and then from above up on the deck, clean out the caulk around the wires, and then you should be able to pull the remaining wire up to the deck.
I rewire my solenoid all from above deck this way, and then I push the wires back into the hole and recaulk.
Time to create page: 0.038 seconds
