Stern rail outboard mounting bracket
4 years 1 month ago #7312
by Lyons
Stern rail outboard mounting bracket was created by Lyons
We recently purchased an IP 420 that has an outboard bracket for the backrest to one of the perch seats. A friend of ours has and IP 320 and would like to purchase the same product. Does anyone know where this is available? I cannot find any
brand name markings on it. Please see the attached picture. Perhaps it was custom made. Thank you. -Bill Lyons
4 years 1 month ago #7319
by MELGYVER
Replied by MELGYVER on topic Stern rail outboard mounting bracket
That looks like a plastic bracket I just bought to replace my UV damaged flaking one, but covered with a SS Plate. I think it might have been “Five Oceans” Brand. Here is the amazon title: Five Oceans FO1586 Rail-Mount Outboard Motor Bracket, Up to 80 lb and 1 inch (25.4mm) Rail Diameter, UV-Stabilized Polypropylene, Stainless Steel Hardware Included… but I got mine at a local chandlery.
4 years 1 month ago #7322
by Lyons
Replied by Lyons on topic Stern rail outboard mounting bracket
Thank you Melgyver! Please let me know if that works. On the IP 420 and IP 320 the vertical portion of the rail is at a slight angle. This product looks like it might only accommodate a 90 degree angle. But maybe there is enough wiggle room in there for it to work.
4 years 1 month ago #7323
by MELGYVER
The one I got was: “Sea-Dog Rail-Mount Motor Bracket”.
I haven’t installed yet, but found my receipt! I’ll let you know if it works on the vertical.
The following user(s) said Thank You: Lyons
4 years 1 month ago #7324
by Lyons
Thanks again, Melgyver!
4 years 1 month ago #7325
by LJD610
Replied by LJD610 on topic Stern rail outboard mounting bracket
I ended up building a simple outboard mount with a strong piece of teak for our 420. I using 3 stainless U bolts for rail attachment. Held up fine with 15hp outboard over many sailing miles
Time to create page: 0.046 seconds
