IP 27 Companion Way Sliding Hatch Track
6 years 1 month ago #6807
by sidmcg
IP 27 Companion Way Sliding Hatch Track was created by sidmcg
My IP 27 track for the sliding companion way hatch just cracked. Hey...it's 32 years old! Has anyone replaced this piece. It looks like plastic or nylon. Nothing looks like it in my research so far.
Thanks...
Thanks...
- justsomeguy
- Thank you received: 3
6 years 1 month ago #6808
by justsomeguy
Replied by justsomeguy on topic IP 27 Companion Way Sliding Hatch Track
Starboard, an expensive HDPE.
www.eplastics.com/sheets/hdpe/seaboard-starboard
The following user(s) said Thank You: sidmcg
- Norm Pierce
6 years 1 month ago #6809
by Norm Pierce
Replied by Norm Pierce on topic IP 27 Companion Way Sliding Hatch Track
These are available from the factory store. Requires one to square cut the old ones with a fine tooth hack saw as close to the sea hood as possible, remove the screws and use the old pieces as a pattern to cut and drill the new (blank) pieces to match the old ones.
- northernsailor
- Thank you received: 2
6 years 1 month ago #6810
by northernsailor
Leonard and Carolyn
Replied by northernsailor on topic IP 27 Companion Way Sliding Hatch Track
HI, the material is a hard plastic known up here in BC as Starboard. Most industrial plastics suppliers would have it. Can be easily cut with a saw, drilled etc.
Leonard and Carolyn
Time to create page: 0.047 seconds
