New Install
15 years 1 month ago #1043 by Gculver
New Install was created by Gculver
I'll be installing air conditioning in my 2002 IP380 over the winter. I'm soliciting recommendations of various brands, suggested number of units and sizes, as well as placement.
Any comments will be appreciated.
Regards,
Glynn Culver
15 years 1 month ago #1044 by hayden
Replied by hayden on topic Re: New Install
I would use one unit...
16000 BTU...
Install in Saloon seat backs...port side...duct fwd and aft from there
CruiseAIR brand.
The following user(s) said Thank You: Gculver, stevetrego
15 years 1 month ago #1047 by Augydoggy
Replied by Augydoggy on topic Re: New Install
Glynn,
On our 420 we have two Cruisair units, 16k for the main salon/aft cabin and an 8k in the fwd stateroom. We find that this arrangement works well for our set-up and maintains comfortable temps throughout the boat, also provides options for running the smaller unit at night with the other one shut off. The 8k is plenty big enough for the smaller spaces up forward. It was felt that the 16k alone wasn't sufficient for cooling the entire boat on it's own. Not sure how that relates to your 380 but I don't think our boats are all that different in size. In colder weather these units work nicely for providing warmth until the water temps reach 38F. We keep our boat between 73-75 in hot weather and 76-78 in cold. Our most recent electric bill (Baltimore G+E) for August was $159.58.
Our 16k is located the same as Hayden suggested. The 8k is installed under the fwd bunk and has one outlet in the cabin and one in the head, with the return at the foot of the bunk. The noise in our stateroom is negligible as long as the fan is on low (setting = 28 in the menu), almost silent. Biggest drawback with this location is getting under the bunk for maintenance.
We run our units 24/7 (except December through February due to cold water) and haven't had any problems with them. Water and air filters require cleaning every two weeks with this use.
Tom
IP420-35
La Vida Dulce
The following user(s) said Thank You: Gculver, Emergpa1, stevetrego
Time to create page: 0.039 seconds
