- Thank you received: 2
Suggestions - IP 40 re chain pyramiding & backing up in anchor locker
- Barney1964
12 years 11 months ago #2497
by Barney1964
Hi all,
we have 77 metres of 3/8th shortlink chain on our IP 40, hull 100. We have a maxwell anchor winch.
Problem is that when retrieving, it backs up - and where the chain is meant to go down the spurling pipe (ie) through the deck, the chain jambs between the gypsy and the bell housing that both covers the spurling pipe and guides the chain down the said spurling pipe.
We are almost always two handed - my wife on the helm and I am forward on deck. Typically, we would not have to retrieve more than 35 metres of chain where we use the boat on Moreton Bay in Queensland, Aust. But that will not always be the case as we expect to be going a lot further afield ... and from time to time, much deeper anchorages....
When retrieving, with hand signals, my wife goes forward to the chain locker and clears the backlog, usually before it backs up. However, when it does backup, the loads on the bell housing - transmitted from the gypsy - are significant. So much so, that recently, one of the two bolts (diameter 7 mm which is also around 3/8th of an inch) sheered flush with the cast part of the windlass - getting that out is another story. But that is not sustainable. My wife going foreward to clear the locker backlog is not always desireable.
I have a number of options:
(a) go back to 5/16 th chain - which does not fill me with confidence - I'd rather 3/8th. (Mind you, we are babysitting an IP 44 for a Danish / Canadian couple who have just sailed her out from E Coast USA)
(b) reduce the chain length - please dont make me do that - I'd hate to be stuck 10 metres short at a critical time
(c) Get some sort of hatch arrangement to allow me to access the chain locker from on deck.... the IP 44 has the two covers which lift to show a lewmar circa 10 " * 8" ocean hatch - but that looks a big job.
I have tried restowing the chain under the ledge in the chainlocker - so there is more foreward and greater storage in the aft end of the chain locker.
That didn't work!!
So, suggestions, particularly from IP40 owners, would be greatly received.
We have a 30 kg Bruce as our primary anchor.
And no, dragging does not seem to be a problem!!
Thanks all from down under
12 years 11 months ago #2499
by Ed Finn
Replied by Ed Finn on topic Re: Suggestions - IP 40 re chain pyramiding & backing up in anchor locker
Barney
Some people,have made a removable plywood or metal plate ledge which they fit into the chain locker.
It is located below the windlass,
It slopes downward and backwards.
Thereby keeping the chain from 'piling' up underneath the windlass
There is a photo essay about it online.
Ed
Ed
12 years 10 months ago #2500
Replied by hayden on topic Re: Suggestions - IP 40 re chain pyramiding & backing up in anchor locker
Lester:
Back in 2002 when we build Island Spirit, we had a chain ramp installed that helps to deliver the chain to the locker. You can see my old photo essay here:
fhayden.com/rockhallfleet/islandspirit/anchor_system.htm
I have seen solutions of PVC tubing and 45 degree elbows and drops, and some tend to clog up like yours. I think this ramp idea is the best way to deal with it. The issue here are the slope needs to be steep enough for the chain to drop. The drop is helped by the chain dropping off the end of the ramp. But then when the chain pile meets the ramp, then the chain back up the ramp. At this point the pile needs to be knocked over and then the ramp works again.
So a solution is to keep less chain in the working side. We have 250 feet of 5/16" chain. When all 250 feet are in the working side, the pile is too tall. So we keep 50 feet to port and use 200 feet on the working side. We stack the bottom full and then end up working with 100 to 150 feet. This pile of chain will fall under the ramp and works very well for us.
Here is a photo of our chain ramp on IP35-165
The following user(s) said Thank You: Barney1964
12 years 9 months ago #2601
by blewtack
Replied by blewtack on topic Re: Suggestions - IP 40 re chain pyramiding & backing up in anchor locker
I have recently purchased an 1993 IP 35 in Florida and I am now traveling down the Caribbean.I am very pleased with the boat except for two things. I fitted 200 ft of chain and we have continuous problems with the chain backing up in the locker and I noticed you have made a board up to help with the problem.I wondered if you had the dimensions to share as I might try to get a friend to make one for me who is coming out to see me in a few weeks.Also we have had a problem with the stern gland leaking more and more and despite tightening it still leaks badly.The packing was replaced 3 months ago is there a better solution you know of ? Many thanks in anticipation Rod Ducker
12 years 9 months ago #2602
by CaptainBW
Replied by CaptainBW on topic Re: Suggestions - IP 40 re chain pyramiding & backing up in anchor locker
Lester,
We have hull 28 of the IP40. We used a section of PVC pipe to lead the chain aft in the chain locker. The pipe is suspended with aluminum strapping. After a bit of adjusting, we don't have any problems with the chain building up or jamming and this has worked quite well. The front section of the pipe is a piece with the top half cut off to accept the chain from the deck pipe. I don't have great pics but here are a few.
[attachment:1]P3170242.JPG[/attachment]
[attachment:2]P3170245.JPG[/attachment]
12 years 8 months ago #2603
to: Rod Ducker
That chain ramp I added to our IP35 is...
30" long
9" wide at top
11" wide at bottom
with a 1 3/4" Batten to keep the chain on the ramp.
Then the top is cut on an angle to make it fit.
The support is a vertical piece screwed to the locker divider and holds up the ramp.
Here is the original photo again.
30" long
9" wide at top
11" wide at bottom
Time to create page: 0.064 seconds
