Prosine 2.0 will not go to float
8 years 1 month ago #6249 by hayden
IPYOA team:
I am noticing and working thru a charger issue this summer. Several resets, and several calls to Xantrex. Today, my third call the tech brought up an idea I have never heard of. Move solar off prosine and flip it. Details below
First my issue.
Charger will display high voltage 14.4 warning when I return after a week away.
Seems like bank has been at 14.4v non-stop cause charger will not go to 13.3v float, hence factory reset and troubleshoot
Wiring:
Prosine positive to PD, house bank positive distribution post
Prosine negative to ND, house negative distribution post
House bank 5 GP31 Lifelines
PD to + battery 1 of 5
ND to - battery 5 of 5
Solar
Blue sky 300i
Positive to PD
Negative to ND
Wind Turbine
Positive to Prosine 2.0 positive output that feeds to PD
Negative to Prosine 2.0 negative output that feeds to ND
Technician said....
Move solar Positve from PD to positive of battery 5
Move solar negative from ND to negative of battery 1
WOW, I never heard of that. Basically, they want the solar feed to be opposite of the prosine feed. They said that the solar can confuse the prosine.
Has anyone heard of this?
8 years 1 month ago #6251 by shawnee
Hi Hayden,
I don't see how swapping connections a bit, as suggested would change anything. Is this a new behavior, or has it been this way?
We have Blue Sky 2000e older (lower current) version of 3000i. And old Heart Inverter/Charger (now Xantrex) with old Link 2000 Controller. All charge sources are connected to battery plus (all batteries connected in parallel). All charge sources include: Heart Freedom 2000, BlueSky 200e, KISS wind, and Balmar 150A Alternator (with Link voltage regulator). We can be plugged in, with solar on, and both chargers will go to float voltage when fully charged. Same if running on engine, with solar on. Wind generator has no controller - just manual on/off. If wind is on, while sailing (motor off), it confuses the Blue Sky and solar cuts back it's charging. (Blue Sky thinks battery voltage is fine and does not need charge).
For negative connections, all loads connect to 500A current shunt, and current shunt goes to battery negative - all connected in parallel.
As for not going to float - could Xantrex be OK, but solar charger be too high and not cutting back? I don't recall Blue Sky algorithms, but if controller thinks the batteries are accepting a lot of current (charge going to batteries), it may not cut back. And if so, the solar would keep voltage up. On our Link System, battery acceptance (at 14.5 volts or so) must be lower than 6 Amps to go to float. I set the current to 1% of 600Ahr capacity (6 x Gp27) (or maybe I set it to 2% - don't recall) I'd have to read Blue Sky manual to review their rules for cutting back.
Our Link System can measure load on battery, as well as output from alternator and/or charger. By subtracting the load currents from the total charge current, the Link System knows how much is going to the battery. So it's fairly smart.
The Blue Sky system is totally independent, and has to figure out by itself.
I''l check their manuals for the 3000i and see if I find any hints that could cause this.
More later - - Drew
8 years 1 month ago #6252 by shawnee
Hi Hayden,
I did some reading on your manuals for the BlueSky and the Xantrex. Of note - both have extensive and complex setup procedures. If not set correctly, it could cause problems.
On BlueSky, the default settings look reasonable for Island Spirit. But if the settings got gronked, and Float got turned off, (possible to set it this way) the voltage would stay at 14.25v, rather then 13.8 (or whatever float is set to). Setup looks rather painful, but doable. Would be good to review and make sure it's set the way you want.
On Prosine2.0, the Xantrex User manual shows default values that might mess things up for you. There is no provision to measure load current. It only measures the output of the charger. The default settings are for a 200Ahr system (2 batteries). And seems to only go to float if/when charge current drops below 1% of C - ie: 2Amps. On the other hand, it should time out after 8hrs, then go to float. Might take some more study on that for me. Looks like it would go back to Acceptance, if the charge current (including load) came back high again.
At least if looks that way to me.
If it really works the way I described, then sitting at the dock, with fridge turned on, or any other load greater then 2 Amps - it could keep going back to 14.25 volts for 8 hrs, whenever a load kicked in - - fridge, bilge pump, or ??
Good luck finding the cause, and checking things out. Definitely review setup for both BlueSky and Xantrex to make sure they still have settings that you wanted.
Fair Winds,
Drew
8 years 1 month ago #6253 by hayden
Drew
Thank you for you very detailed study and ideas to look into. I have been running 100% off solar and wind for 12 days now. The Blue Sky runs it all. So I have left the charger off as I look into this. I have been thru this prosine 2.0 charger set up many times since 2001. This is the 2md one. I reset it to factory the other day and reconfigured all. So I know it's set up right.
I guess I should look at the solar config and review that.
For now, all systems run great as long as i don't need a shore power charger. It's just odd, prosine said reverse my solar input. I never heard of that.
My gut says the prosine is shot, lost its brain but works as an inverter just fine. A replacement is 1200$
Not sure I need it. I will let you know more as I discover more.
8 years 1 month ago #6254 by SLaz
Hi Hayden,
I’m not an engineer, and Drew certainly seems to have a better bead on this topic than I can hope to. The one small, but maybe useful, contribution I can make is to note that all DC charging devices should be attached to the same battery. I have two banks of solar panels fused separately but mastered by a Blue Sky 3000i (the tech support people were incredible in helping me get setup and finding the least expensive source as well! Highest recommendations.) and a wind generator. The charger and inverter are separate, but the inverter is attached to the same battery as well. As I’m writing, I realize I can’t say where the charger is attached. Sorry. But the one battery principle is pretty important, I’m told. Can’t evaluate it as an EE.
See you on the 4th. In Delaware City now and making my way south. Looking forward to finally pressing flesh and thanking you in person for all your help!
Steve
8 years 1 month ago #6255 by hayden
Steve:
Thank you for the reply and the info. All my power sources feed to the PD, positive post of my 5 battery house bank. The negatives from all my power sources connect to the ND, negative distribution post of the same house battery bank. Everything seems to work just fine while anchored out as it has for many years. I spent this summer on the dock, plugged in and with my charger on, like usual and every time I came back the Prosine reported high voltage at 14.4v. So it is simply.....go cruising, get off the dock, live on anchor or a mooring ball :-)
We will be docking this weekend at the SSCA GAM and I will check it all out there again.
Thanks for the reply.
We will see you in Annapolis at the IPYOA NOON lunches. Fun times to visit.
Moderators: acajun, shawnee
