Replacement Rudder for 1990 IP35
- Miss Adele
9 years 7 months ago #5531
by Miss Adele
Replacement Rudder for 1990 IP35 was created by Miss Adele
Who can provide a replacement rudder?
9 years 7 months ago #5534
by apowell
Replied by apowell on topic Replacement Rudder for 1990 IP35
About three years ago our IP-35 rudder was discovered to be saturated with water. The rudder was completely re-built by Shelter Island Boat Yard in San Diego. The location may not be convenient to you, but they did a good job, an no problems since........I might add that is was not a cheap fix. I recall that at the time the factory would re-build the rudder, but you had to send the shaft back to FL and end up with a shipping issue and a "what to do with the boat while the rudder is gone" issue. Also, I am not sure if the factory is still prepared to do this work.
9 years 6 months ago #5537
Replied by hayden on topic Replacement Rudder for 1990 IP35
Miss Adele:
Use the contacts page here and email JERRY SWARTZ at the IPY factory and he will give you the price on the new rudder. I would buy it from the factory.
Time to create page: 0.048 seconds
