Water treatment with hydrogen peroxide
11 years 8 months ago #3782
by ErBrown
Water treatment with hydrogen peroxide was created by ErBrown
Howdy folks,
Now that our boat is spending more time in the marina we'd like to prevent our water tank from getting funky. Does anyone have a good resource for how to calculate exactly how much peroxide we should be adding on a per gallon basis?
We have the higher 27.5% peroxide on board but want to be sure we use the right amount.
Erin
Erin
11 years 8 months ago - 11 years 8 months ago #3783
Replied by hayden on topic Water treatment with hydrogen peroxide
Erinn
it is not your water tank that gets funky, but rather the water lines. You need to treat your waterline every year or every 6 months.
Here are the details in this post.
www.ipyoa.com/forum/44-plumbing/783-water-treatment
Last edit: 11 years 8 months ago by hayden.
11 years 8 months ago #3784
by ErBrown
Replied by ErBrown on topic Water treatment with hydrogen peroxide
Thanks Hayden,
As other folks mentioned on the thread you linked to, unfortunately we're not on the boat regularly at the moment (couple weekends a month). The previous owner did do us the favor of plumbing the system so it's fairly easy to sterilize the lines with bleach water, a bit of a pain but not bad.
I believe the problem is that we're not pushing enough water through the system to keep it fresh. It's currently not bad, but I'm concerned about keeping it from growing anything nasty. I had heard it was possible to do this with peroxide and the previous owner left us a half bottle of the concentrated stuff but am not sure on the amounts.
Also in the thread you linked to, it mentioned a recommendation for a filter to remove chlorine from the water when filling the tank. We've been using a filter every time we fill but I'm not positive it removes chlorine, is there a specific type you recommend for this?
Thanks again,
Erin
Thanks again,
Erin
11 years 8 months ago #3785
Erin:
Other IP owners use
Purogene Long Term Water Purification Treatment
You can read about this product here.
www.bayteccontainers.com/wattreat4oz.html
AS for water filter, I use a GE house water filter with a charcoal filter. Filter housing cost about $17 and filter is about $10 available at Home Depot.
Other IP owners use
- rlwestlake
- Senior Member
- Thank you received: 2
11 years 8 months ago #3793
by rlwestlake
Replied by rlwestlake on topic Water treatment with hydrogen peroxide
We use the same concentration that you have on board, acquired from a pool supply store. One ounce for each 20 gallons has worked for us. Read the label if it still has one (or google the MSDS) and use proper precautions. Re chlorine: the charcoal in the filter is doing the work. I have measured the free chlorine in the water on both sides of our filter, and it helps, but does not remove all of the chlorine. Hope this helps.
11 years 7 months ago #3819
by wanderer
Replied by wanderer on topic Water treatment with hydrogen peroxide
I have owned my IP-35 for 21 years. For most of that time I have filtered the water going in with a charcoal filter to remove the chlorine in an effort to abate the calcium formation inside the tank. I treat the tank with ordinary grocery store hydrogen peroxide, using about 16 ounces to a tankful. I have never treated the lines with chlorine (though I have replaced them once), but will start doing that as well. If my boat sits for a couple of months in the Florida sun, I do have to run the facets to get the foul smelling water out of the lines. After a few minutes the water smells and tastes fine, which supports Hayden's theory that it is the lines that are the problem.
Time to create page: 0.046 seconds
