Gori 3-blade folding prop ... experience on IP 380s?
- MessingAbout
13 years 11 months ago #1710
by MessingAbout
Gori 3-blade folding prop ... experience on IP 380s? was created by MessingAbout
Any insights or experience with a 3-blade folding prop for an IP 380 as replacement for the current 3-blade fixed prop?
We had 2 and 3-blade folding props on our earlier boats, and worked very well, but those were in our club-racing days.
We're underway several weekends a month cruising on the southern Chesapeake Bay, and still dabble in club racing as 'cruisers" here on the Chesapeake.
Any recommendations appreciated.
Chess and Karen
IP 380-88
The Belle of Virginia
thebelleofvirginia.blogspot.com/
Chess and Karen
IP 380-88
13 years 11 months ago #1715
by tidesinn
Replied by tidesinn on topic Re: Gori 3-blade folding prop ... experience on IP 380s?
We do not have a folding prop as my philosophy is to "keep it simple" and that's one less maintenance issue and thing to break. Barnacles in Chesapeake can be a problem for folding props. With that in mind, IP owners using the Kiwi non-metallic folding prop have reported good results.
Mark Lawrence IP380-132 Tides Inn
- spinaker75
- Senior Member
- Thank you received: 5
13 years 11 months ago #1716
by spinaker75
Replied by spinaker75 on topic Re: Gori 3-blade folding prop ... experience on IP 380s?
Chess,
I put an auto prop on my ip 37 last spring. I was very pleased with the improved performance in all phases, sailing, motoring and motor sailing. Picked over a knot motoring, but i had a failure while I was cruising this fall. Had to hire a diver to come change it out with the old three blade prop which I luckily carried as a spare. The factory said it was a very failure and we are currently negotiating on who should pay for what since they just overhauled it in the spring. I am probably going to try the autoprop again but I'll keep the old prop on board as a back up.
Bob Younh
Bob Younh
- MessingAbout
13 years 11 months ago #1718
by MessingAbout
Replied by MessingAbout on topic Re: Gori 3-blade folding prop ... experience on IP 380s?
Bob...appreciate the assessment. Heard the same from a couple of locals here with large Beneteaus and Hunters. A knot more makes big difference on the long hauls.
Best wishes for the holidays!
R/Chess and Karen
IP 380-88
R/Chess and Karen
IP 380-88
- MessingAbout
13 years 11 months ago #1719
by MessingAbout
Mark...thanks!
Simple is always better, and fixed over adjustable reduces number of moving parts. Appreciate that all too well. Had folding props on our Pearson and later on our O'Day. Never had a problem here on the Southern Bay. Key was underway often and good bottom paint/prop-speed sealant on the prop. Our slip is in Willoughby Bay on the Navy Base...and lot of freshwater run-off from the airfield and heliport directly into the marina, so low salt-level...so hardly ever a barnacle problem, just algae slime build-up in the summer months.
Would like to put a marker down for a potential Southern Bay Rendezvous in Apr/May 13. Maybe up in Sara's Creek,willoughby Bay, Hampton,...?
THanks again.
R/Chess and Karen
IP 380-88
THanks again.
R/Chess and Karen
IP 380-88
- Chuckellis
13 years 11 months ago #1720
by Chuckellis
Replied by Chuckellis on topic Re: Gori 3-blade folding prop ... experience on IP 380s?
I also experienced and Auto Prop failure just recently. While moving Ellis Island from Maryland to Florida I lost reverse propulsion. I had the boat hauled and found that two of the three blades had lost their bearings. The prop has about 600 hours.I plan to send it in for repairs. Any suggestions on where I should send it.
Chuck Ellis
Ellis island
IP 32 - 099
Chuck Ellis
Ellis island
IP 32 - 099
Time to create page: 0.047 seconds
